need more articulation
Old Jun 27, 2009 | 04:25 PM
Broz's Avatar
Default need more articulation
I have a 2.5 bb with 35'' tires with extended bumpstops. All the rest of my suspension is stock. My articulation is minimum (which i expected) but im wanting to get as much as possible with this setup. I know i need longer shocks and some swaybar links. But what else should i add to get as much axle drop as possible.
And i know a bigger lift would do the job and eventually ill get one but this is what ive got now
Old Jun 27, 2009 | 04:27 PM
ckmehl's Avatar
Default Coils
i think coils would work. just add some coils for a 2.5" lift.
Old Jun 27, 2009 | 04:29 PM
NH4X4's Avatar
get some long travel shocks and put your stock bump stops back in or get some different ones,
Old Jun 27, 2009 | 05:01 PM
09rubicon's Avatar
Just keep tabs on our stock brake lines, breather hoses, and wiring harnes (if applicable) so you dont tear, rip, break something. From your described setup you should be fine.....but you never know.
Old Jun 27, 2009 | 06:33 PM
style_front's Avatar
ORE double throw down front and rear coilover system should fix what ales you
