Need some quick trqck bar help!!!
Old Jul 17, 2015 | 07:01 PM
sea bass's Avatar
Default Need some quick trqck bar help!!!
Hope this vid works:
http://magis.to/fycqWQRTGEIsP3kGDmEwCX17?l=vsm&o=i&c=c
Made this vid with a free iPad app so not sure if it'll work. Been having a hard time tracking down by wandering issue. I have quite a bid of movement and axle shift when dry steering in my garage. The axle side bushing rally squishes a lot and moves as you can see in the end of the vid. Is this more than usual??? With both ends moving as much as they are, is this my problem?
Thanks!!!
Old Jul 17, 2015 | 08:28 PM
mhockey9090's Avatar
Vet Army
Couldn't hurt to replace the bushings. That does seem like a bit of play in those.
Old Jul 18, 2015 | 06:07 AM
bman's Avatar
Have you looked at/determined what your caster is? This could also cause a flighty or wandering problem when driving down the road.
Just a thought
Old Jul 18, 2015 | 06:14 AM
bman's Avatar
I meant to include this link for you.
Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
Old Jul 18, 2015 | 06:16 AM
sea bass's Avatar
After I installed my lift about a year ago, I took it in to my local shop and they confirmed it was around 4.5*. I haven't messed with it so it should be the same. It so only recently started driving like this - the only thing I changed was the northridge bolt kit.
Old Jul 18, 2015 | 06:18 AM
OH9JK's Avatar
JK-Forum Ambassador
I'd contact the manufacturer of your track bar and show them your video.
It seems a little excessive to me but I run a Rock Krawler TB that has a Heim type joint on one end and has a massive bushing (flex joint) on the other....it doesn't flex like that one.
Old Jul 18, 2015 | 07:03 AM
Albino Lizard's Avatar
Thats too much flex for sure. I prefer to stick with stock. Use a relocation bracket at the axle and it will function great.
Old Jul 18, 2015 | 08:11 AM
sea bass's Avatar
I'll contact manufacture on Monday. I was gonna keep stock but it wouldn't work with the sector brace.
Old Jul 18, 2015 | 08:32 AM
A.W.D.eLussey's Avatar
Check torque specs on track bar bolts. I believe it's 65 lbs. that will happen is there not tight enough.
Old Jul 18, 2015 | 09:01 AM
JKBud's Avatar
Torque spec for the track bar is 125ft lbs.
