Need some Wheel Advice
Old Mar 3, 2008 | 09:04 PM
derekls's Avatar
Default Need some Wheel Advice
Ok so I am looking at the Crager Soft 8 series 397 black steel wheel......... I think they look great and found a super deal on them..............
My question is can I run a 15 x 8 with 4'' of backspacing and be fine? ....
I was also wanting to run 32 x 11.5 x 15 BFG M/T TA
Would this set up work fine or do i need to change the size of tire, and/or size of rim/backspacing
I do not want to lift my jeep as of right now due to warranty complications...
Old Mar 3, 2008 | 09:10 PM
derekls's Avatar
Well crap.........
I just noticed the wheels I was looking at is a 5 on 4.5 bolt pattern....
and the only ones I can find in the series 397 is 16 inch
I was wanting 15's
Can any one reccommend a tire like the series 397 in 15 inch.... or do you know where you can get 15;s in Crager 397 in 15 inches with the right bolt pattern and backspacing?
Edit:
OK Found some in 15 x 8 with 5 on 5 and 4 inch backspacing at jegs........
Thanks
derek
Old Mar 3, 2008 | 09:21 PM
RedneckJeep's Avatar
Careful. Not all 4" backspacing will fit.
Old Mar 3, 2008 | 09:27 PM
derekls's Avatar
Any ideal what backspacing would work, on jegs the on 5 on 5 bolt pattern is the 4 inch backspacing only:
http://www.jegs.com/p/Cragar/754162/...ItemAdd#bottom
Old Mar 3, 2008 | 10:01 PM
derekls's Avatar
What about the 15 x 7 with 4'' of back spacing, should that fit?
and If it does, with the 15x 7 ........would a 32 x 11.5 x 15 even work on that rim?
