Need Spring advice...
Old Mar 17, 2014 | 09:43 PM
courtsm3's Avatar
Originally Posted by JLsJK
You might try the rear 3 inch synergy springs.
Agreed. Im on my third lift and my synergy coils are the best. Progressive rate, great length and beautiful ride.
Old Mar 18, 2014 | 12:49 AM
TJJK's Avatar
Everything works in theory, and that goes for non-linear coil spring. Go with the best linear set out there, that's appropriate for the weight your running.
Old Mar 18, 2014 | 07:50 AM
markresc's Avatar
Originally Posted by LidLess07X
Do you always have the weight on? Is your lift where you want it when not loaded? Maybe try a set of Airlift airbags ? I have them on my coil-spring Ram and I just pump them up when I have to carry a heavy load. Good excuse for an on board air compressor.
The load is rather constant. I only use the hard top (soft top too inconvenient with rack). Usually have box on top unless I am wheeling. ...and just way too much crap inside... I think springs would likely work out ok since the load is constant... Do like the idea to got me an on board compressor, though lol
Old Mar 18, 2014 | 07:52 AM
markresc's Avatar
I'm intending to use the stock springs with the Aev extenders for now... that was fit a 2" lift... would a 3" spring be too much on these? Not enough $$$ to consider shocks right now...
