Need steering stabilizer advice
Old Jan 29, 2014 | 05:44 PM
mike moyer's Avatar
Default Need steering stabilizer advice
Have a 2011 wrangler no lift yet with 33" tires I wanna upgrade my stabilizer what a good one? Stock looks tiny and I can tell is weak now. Recommendations?
Old Jan 29, 2014 | 05:45 PM
Cjsmith4's Avatar
Other than it "looking weak", do you have any other reasons you want to upgrade it?
Old Jan 29, 2014 | 05:49 PM
mike moyer's Avatar
I starting to bump steer(think that's what they call it) a little now I have 65k on it should I not change it yet?
Old Jan 29, 2014 | 05:56 PM
meep97's Avatar
a SS is not going to fix your bump steer.
What size lift are you running?
Old Jan 29, 2014 | 05:57 PM
mike moyer's Avatar
No lift with 33" nitto terra grapplers.
Old Jan 29, 2014 | 05:59 PM
meep97's Avatar
What makes you believe you have bump steer?
Old Jan 29, 2014 | 06:01 PM
Cjsmith4's Avatar
What are you feeling as you drive. I have a feeing it isn't bump steer and an upgraded stabilizer isn't what you need. Tell us what you feel and we will help you diagnose and fix the problem.
Old Jan 29, 2014 | 06:10 PM
mike moyer's Avatar
Well every time I hit a bump it kinda pulls the the side.(steering wheel a little too) Not to bad. I had the alignment guys look at my jeep the said my tires toe it a little but it's not bad enough for them to do an alignment.. No abnormal tire wear.
Old Jan 29, 2014 | 06:26 PM
Dahmer's Avatar
I had this problem and it was looseness in the track bar bolts. I bought some new bolts and lock nuts. I don't remember the size but there are some threads on that. Play in the steering can cause issues also.
Old Jan 29, 2014 | 06:27 PM
meep97's Avatar
If it only pulls the steering wheel a little and the jeep itself is wondering more than the steering wheel is turning, I would say something within your steering is worn out. If you had bump steer, the steering wheel would turn just as much as the wheels were.
Like this
