need tire and rim help
will 275/70/18 goodyear duratracs work with these rims and no lift http://www.ebay.com/itm/18-inch-KMC-...item45f73a46da
I have a similar setup. With 5" backspace, and a factory front bumper with the lower air dam - the tire will rub on the air dam when turned fully to the right (not left for some reason). I am removing the air dam or cutting it for now and seeing if it affects MPG too much.
After all, the Jeep is a brick and the air dam helps smooth the flow under it.
