Needing help finding a good suspension set up!!!
Old Mar 3, 2011 | 02:08 PM
Default Needing help finding a good suspension set up!!!
I just found a great deal for nitto mud grapplers 38x15.50 r 20 and i was wondering what kinda of lift should i be looking at to be able to fit these bad boys... and if there is any modifications or a set of gears or performance items i need to be thinking about while doing the install....?
Old Mar 3, 2011 | 02:17 PM
Pluke the 2's Avatar
either of these lifts:
https://www.jk-forum.com/forums/show...*POSERS-SHOTS*
Old Mar 3, 2011 | 02:18 PM
BKGM Jeepers's Avatar
You'd need some mods to get them under you. If you want to wheel that set up, you'd need more...
At a minimum, you'd need 4.5" of lift + tube fenders and more to run those tires PLUS bump stop extensions. You'd also need gears and stronger axles...
Old Mar 3, 2011 | 02:25 PM
gripthor's Avatar
First off congratulations on the new rubber.
You should sit down and read the first hundred pages of so of this forum, going with tires that sizes requires quite a few things and you have many options. There are many little things your going to want to keep your rig running smooth.
If you search for others that are running rubber that size you'll see the shopping list of equipment they have to keep them turning .
Happy Reading
dillUSMC's Avatar
to run 38's, itll prolly cost you three time wut you paid for the wheels and rims. you'll need axles, gear, suspension, CA, etc etc, the list goes on
Old Mar 3, 2011 | 02:38 PM
Abacabb's Avatar
Teraflex or Rock Krawler Lift - Gussets/Sleeves - 5.13 or 5.38 gears
Old Mar 3, 2011 | 02:44 PM
TeraFlex's Avatar
Sponsoring Manufacturer
TeraFlex 6" Long Arm kit with 38's.
Old Mar 3, 2011 | 03:05 PM
Default Wow!!!
THis Kit is sIck!!!!!! this is just what i want... how much will this end up costing me?
Old Mar 3, 2011 | 07:13 PM
Default ????
Originally Posted by TheDirtman
Evo double throwdown with the kings would be my lift of choice.
http://www.offroadevolution.com/stor...UBLEDOWN-FRONTAttachment 133214
Is this a full suspension lift kit?
Old Mar 3, 2011 | 07:31 PM
smellytuna's Avatar
This Jeep is awsome!
