New Drive Shaft
Old Jan 30, 2009 | 02:17 PM
ckmehl's Avatar
Default New Drive Shaft
i want to put the TeraFlex 3" lift on my JK. what i do not know is what kind of drive shaft do i need to buy for the front. i'm an idiot about this. i have no idea what i need.
Old Jan 30, 2009 | 02:26 PM
08{GA}RUBICON's Avatar
There is a ton of info on drive shafts, what to get, how to put them in etc... In the upper right hand corner you will see a search button. You can use that function to find out a lot of info. Check out JE Reel and Tom Woods Drive Shafts.
I recently installed a rear JE Reel 1350!
Check these out.
https://www.jk-forum.com/forums/jk-write-ups-39/installing-je-reel-1350-rear-driveshaft-28160/
https://www.jk-forum.com/forums/show...ht=drive+shaft
Old Jan 30, 2009 | 02:37 PM
ckmehl's Avatar
cool thank you for the two names. and the links.
Old Jan 30, 2009 | 02:42 PM
TeraFlex's Avatar
Sponsoring Manufacturer
TeraFlex sells driveshafts.
Old Jan 30, 2009 | 02:48 PM
Young-Jae, Yoo's Avatar
I think you don't need to hurry up to replace drive shaft with 3rd party one.
Once you have seen leaking grease around CV joint (transfer side) and also
damaged boots (due to interference with tranny) then its signal to check new
one.
At the moment, nothing seems superior than OE part for drive shaft, my opinion.
I think hub conversion is more valuable than to replace drive shaft.
Old Jan 30, 2009 | 02:53 PM
guinness's Avatar
one.
I agree that you might want to wait until you can confirm a problem exists; however, if youlook at the thickness of a stock vs. aftermarket shaft there is a significant differnce in favor of the aftermarket. JE Reel, woods, teraflex and others are all excellent choices.
Old Jan 30, 2009 | 05:31 PM
nukeman's Avatar
There's also Tatton driveshafts. I have a freind who just installed one ($235.00 deivered) and I'm quite impressed with it. Awesome quality and great price/warranty. Check them out on Ebay.
Old Jan 31, 2009 | 08:52 PM
blazer4949's Avatar
Added Rubicon Express front driveshaft with 3" Full Flex Teraflex lift kit.
Problems.......vibrates. Took off and no vibration.
Sent out to be re-balanced, still vibrates.
May buy Teraflex driveshaft and see what happens.
Old Jan 31, 2009 | 10:58 PM
chuck45's Avatar
Did you check your pinion angle and caster? Aftermarket driveshafts have different requirements than the stock POS.
Old Jan 31, 2009 | 11:10 PM
chuck45's Avatar
one.
I don't agree unless your wheeling is light or nonexistant. If you disconnect your swaybars you'll have enough articulation to go beyond the design parameters of the stock DS. It will fail, and if Murpy is riding shotgun it will be at the worst possible time.
The OE driveshaft was designed to give the Commander and Grand Cherokee a smooth ride. It should never have been put inthe JK. It was not designed to live with aftermarket lifts and control arms with flex joints that provide more articulation.
Why would a hub conversion be so valuable? What is he great benefit to justify the cost; which is not insignificant. I've seen enough failed stock JK drieveshafts to know it is a weak link and should be replaced.
