New Drive shafts or not?
Possibly looking at upgrading to a RC 3.5" Series II Suspension lift for a 09 JKU. Is buying extended drive shafts necessary, or recommended? I would rather spend the money all at once rather than breaking something and fixing it down the road. I do plan on wheeling it not real hard core but be able to put it through a decent beating and i do plan to disconnect the sway bar.
And if new drive shafts are recommended do i need both or just the front?
Thanks
JK-Forum Founder
please be advised that this information only applies to 2007-11 JK's. 2012's have different issues and ones that apply to both autos and manuals.
Don't mean to hijack, but what is different about the 12. I have a 12 unlimited sport manual with 3.5" (2.5 tf coils and 1.0 tf spacers) up front and 2.5 tf coils in the rear.
with just 2.5" of lift and shocks that are made specifically for it, nothing will happen. if you go taller or install shocks that allow for more droop, your front drive shaft will catch on the lip of the sump pan when flexing and, in addition to tearing the slip shaft boot, you will eventually start peeling the pan down and potential cause a leak.
do you still recommend the Coast 1310 DS?
JK-Forum Founder
yes, i would still recommend a coast 1310.
