New to forum, have some ?'s
My wife couldn't drive a stick either. But I refused to buy a Jeep with an automatic. It took me three days to teach her to drive it. Now I can't keep her out of it, and she said " I was right " ( that never has happened before )
Now her "mod list" is bigger than mine. LMAO
If all your doing is trail riding with a mud hole here and there why not just keep it stock for now? That way if you need warranty work done they will have a harder time declining it under warranty. You can learn the vehicles capabilities and let's face it they are pretty darn capable out of the box, especially for what it sounds like you are going to be doing. If you like the look of it lifted then by all means slap a budget boost on there and join the club! Just be careful before you know it your little weekend toy could eat you out of house and home! Either way, welcome
I guess my main reason for the lift is to make it a little more aggressive looking. I have owned many 4x4 vehicles that were not lifted including a 1966 Bronco and never had any problems with where I have taken them. I am quite sure I would not have any issues with the stock setup on my JK so maybe just keeping it stock will save me some headaches? It stands fairly tall now so maybe I just level the front with the back? Has any one done just that? If so and you have a pic that would be great! Thanks everyone for your advice it is greatly appreciated!
Former Vendor
Typically the BB lift kits come with a rear track bar bracket but nothing for the front. The offset of the axle in the front is so minimal that it really isn't noticed.
One thing to keep in mind is that as you lift a vehicle it changes the operating angles of everything. It will actually bring the front axle closer to the rear of the vehicle and bring the rear axle closer to the front of the vehicle. Again most people don't notice it. The only thing that customers have mentioned when installing a budget boost is that the steering feels "flighty". This is caused by the change in caster. This can be corrected with a set of adjustable control arms or drop brackets. The adjustable control arms are the better way to go because it gives you more ground clearance however if you do not plan on wheeling the vehicle then drop brackets would be an economical solution.
We like to recommend the Rock Krawler 2.5" Flex System as the most basic kit. This is because it is complete enough to wheel for a while and easily allows to upgrade to even more complete kits as your needs/budget allow.
Feel Free to PM us if you would like to discuss more in detail or would like a quote.
My boy put that exact kit you outlined on his JKU Sport. He bought my Rubicon wheels and tires and added 1.5" spacers. He did it for looks and the little extra clearance. He has no complaints about how it drives. He did not modify the front trackbar and I think he got the bracket for the rear. He is running the stock shocks with the extensions. His steering wheel was just very very slightly off which just took a minute to fix. Barely turned the adjuster.
I just looked at the Teraflex leveling kit and maybe this is my best option. From what I read the front raises 2" and rear 1". So I guess all of the issues that come with using the 2.5" budget boost will be eliminated if I just use the Teraflex leveling kit instead? Or will I still have to worry about axle alignment issues? Also I know that many on here are against wheel spacers that are not attached to the axle, but in all honesty for normal driving conditions how awful are the RC ones that retail For $60 a pair?
Shouldn't have to worry about track bars or control arms with just the leveling kit. No exhaust issues either. Really simplifies things for a rig that will be used for mild trails and IMO is a good looking setup.
Regarding the "rake" -- If you haul a people and stuff in the back it will tend to level out. If you install a higher lift in the front so it sits level unloaded, it will tend to nose up as it's loaded.
