New Gears
Old Mar 14, 2010 | 06:44 AM
ripmover's Avatar
Default New Gears
I am looking to upgrade my gears. Can someone give me some idea on what I should be paying to have them installed?
Old Mar 14, 2010 | 06:55 AM
redrockin7's Avatar
Really depends where you are and how hard you look. Here in PA, I've found someone who would do them for $550 parts, $300 labor = $850 total. This was a guy who did them on the side. Then there are other shops that want $1700-2000 installed.
I think the average going rate is about $1200-1300-1400 for installed gears, including parts (gears and overhaul kits).
Old Mar 14, 2010 | 06:56 AM
CJ THAT WENT JK's Avatar
Couple hundred depends on who and where. I paid 150 for mine, but that was a pretty good deal considering he was a buddy of mine. I have been told all the way from 400-600. I recommend shopping around though.
Old Mar 14, 2010 | 07:24 AM
No no no. I wish. that was for per axle with fluids and labor. Not including parts.
Old Mar 14, 2010 | 07:30 AM
I know. Its good to have friends. All of mine just seem to be in offroading. Lucky me.
Old Mar 14, 2010 | 08:32 AM
ripmover's Avatar
What is ECTD?
btw - Wow had no idea would cost that much. I better start shopping around
Old Mar 16, 2010 | 04:14 AM
ripmover's Avatar
Thanks for all the help. Now Ijust need to decide on 4.88 or 5.13
Old Mar 18, 2010 | 05:04 AM
ripmover's Avatar
If I have an Automatic with 35s and do mostly hwy driving. Should I get 4.88 or 5.13?
Old Mar 18, 2010 | 05:06 AM
joneszj's Avatar
513s because its an auto. I am putting in 513s w/ my 6 spd on 35s only because I plan to jump to 37s eventually
Old Mar 18, 2010 | 07:33 AM
jeepmedic's Avatar
I had 5.13s put in mine with 35's and an auto. Im picking it up tomarrow..will post up with the results.
I would also take into consideration you may need new axle seals...$150, and you may also need new clutch plates for the rear if you have a limited slip...$150 if the are worn...
Programmer for the speedo and ratio change...it all adds up
