JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   New Gears (https://www.jk-forum.com/forums/modified-jk-tech-2/new-gears-154442/)
acorkum Dec 8, 2010 12:38 PM
New Gears
So I lifted my jeep 4" and put 35" tires on it. I am getting the superchips flashpaq to reprogram my speedo and other adjustments. Should I put a new gearing in it?? If so what gearing? I mostly use my jeep as a daily driver but do some off roading at places near my house but nothing to serious. Any ideas?
AlexjeepVb Dec 8, 2010 12:41 PM
2 or 4 door, auto or 6 speed?
NH-JK Dec 8, 2010 12:49 PM
Auto 5:13 auto rubicon 5:38
6 speed Id go 4:88 since it's a daily driver...
Tons of threads on this do a quick re-gear search. Good luck
acorkum Dec 8, 2010 12:50 PM
Its an automatic 4 door X
nthinuf Dec 8, 2010 12:52 PM
You go off-roading in your car? Why not just use the JK? :bleh:
Open the FAQ's stickied to the top of this modified area...
AlexjeepVb Dec 8, 2010 02:21 PM
I think you would be happy with 5.13 gears , if you plan to go to 37s or wheel alot do 5.38
JK.nick Dec 8, 2010 02:24 PM
Auto: 5.13s is BEST. Do you drive on the highway often? If so then consider 4.88. That's what I'm having installed now :thumbsup:
nthinuf Dec 8, 2010 02:40 PM
Open the faq's linked above and start plugging numbers into the chart.
5.13's are as low as you can go with your front D30.
(if you have any plans of swapping to a front D44, then wait and go with 5.38's)
Also, see page 3 here for some good info from planman that may help...
https://www.jk-forum.com/forums/show...itude%29/page3
There is quite a bit of evidence that this is incorrect. Higher rpm's will let you stay in OD without downshifting, which raises rpm's a lot higher, which reduces mpg's...
JK.nick Dec 8, 2010 03:39 PM
You are right, but it all depends on how you drive. I'm no gear expert, this is just what I was told. Excuse me if I'm completely wrong LOL :yup:
hdrider Dec 8, 2010 03:55 PM
Because of you D30 up front you can't go 5:38's so 5:13's it should be.
© 2026 MH Sub I, LLC dba Internet Brands
