New lift help
Originally Posted by mkjeep
ex. what happens when you lose a driveshaft and install an aftermarket double cardan?
Have there been any issues with the tracbar bracket/drop pitman? What was the 'fix'?
Again, you may have no issues with this, or any other, lift, but there is a reason for the some kits having very low prices. Instead of jumping into the lift decision, spend some time on the research...
The RC lft you are looking at has fixed lower control arms. If you are buying a lift with control arms you would be better off with adjustable control arms so you can set the caster.
Check out the components. For a little more money there are lifts that are a better value.
Originally Posted by msp1972
I've been reading so many reviews about Rough Country and some people like them and some say that they are the worst. I need something to clear 35's with some minimal non aggressive offroading. I was actually looking at the new 3.5 from Rough Country in the new issue of JP Magazine for $500. It has shocks, coils, and also lower control arms with a new Pitman arm
This kit will have no problems with clearing 35s with flex, al long as you have proper backspacing or wheelspacers on factory wheels.http://www.roughcountry.com/jeep_jk_combo.html
Make sure you order your Rough County stuff with a Rough Country vender on this fourm, they will give you 10% off
Edit: i see you already have wheels that have 5 inch backspacing, you should be alright with clearance
Originally Posted by mkd1993
this the one you are talking about?http://www.roughcountry.com/jeep_jk_3-seriesII.html
If your wheels are aftermarket, then you can always get some spitertrax wheel spacers to make your back spacing(they are 1 1/2 inches thick, but im not sure exactly how much backspacing they add, im guessing about one inch)
