new with some questions
Old May 25, 2017 | 11:51 AM
seb0074's Avatar
Default new with some questions
i have a 2012 2 door wrangler with cooper discoverer AT3 LT275/70R18 tires. i want to put a lift kit on it, but will i need new tires also?
Old May 25, 2017 | 12:02 PM
Hail2Ale's Avatar
No you don't need new tires, they may just look small depending on how high you are lifting the Jeep.
Old May 25, 2017 | 12:10 PM
resharp001's Avatar
Loved
Community Favorite
+1 ^^ It's all going to be relative to how you want it to look, but you don't "need" larger tires in order to lift it. 2 to 2.5" is probably the cut off where anything above that would start looking a bit odd.
Old May 25, 2017 | 12:11 PM
Northridge4x4's Avatar
Sponsoring Vendor
What size lift are you wanting to run? Your tires are basically 33" tires, so with a smaller lift in the 2-2.5" range it should look ok. But to answer your question, No, you don't need new tires. Depending on the lift manufacturer, you may need wheel spacers with stock wheels though.
Oh, and Welcome to the forum!
Old May 25, 2017 | 12:41 PM
nthinuf's Avatar
Of course you need bigger tires, everyone needs bigger tires. What a silly question ...
Old May 25, 2017 | 08:30 PM
jordy's Avatar
Loved
Community Favorite
Depending on how deep you choose to get into the forum, you'll find that you can actually go with huge tires and no lift. Welcome to the rabbit hole!
Old May 26, 2017 | 02:30 AM
jadmt's Avatar
JK-Forum Ambassador
that is what my buddy ran on his 2 door with aev 2.5" looked fine.
the one on the left.
Old May 26, 2017 | 09:56 AM
Trail Jeeps's Avatar
Former Vendor
You'll do just fine with a true 2.5" lift, especially a nicer kit that gives you a level height adjustment. With smaller tires a level Jeep is key, the factory rake tends to make it look more "lifted" and makes the tires appear smaller.
