New steering stabilizer with lift?
Old Apr 5, 2013 | 01:11 PM
Hawaii 5-0's Avatar
Default New steering stabilizer with lift?
Is it really necessary to replace the steering stabilizer when you lift? I'm about ready to put my OME 2 inch lift in with 33s. I took off my old stabilizer and checked it. Seems tight and functional to me. Should I just save my money?
Old Apr 5, 2013 | 01:16 PM
sgtkersh's Avatar
Nope. You only need to replace it when it's worn out or broken. There's no reason to upgrade. A steering stabilizer is basically a band aid anyways. It's there in case you have a blow out. If your suspension is right, you don't need it for driving. If your suspension is not set up right, a bigger/better stabilizer just masks the real problem.
Old Apr 5, 2013 | 01:17 PM
sgtkersh's Avatar
But, a relocation bracket is really smart to move it up higher since it is on a really vulnerable place.
Old Apr 5, 2013 | 01:29 PM
Hawaii 5-0's Avatar
Mines already up and out of the way on the backside of the tie rod from the factory.
Old Apr 5, 2013 | 01:33 PM
sgtkersh's Avatar
Then you should be good to go. Wait until it's worn out.
