New Tire Size Speedometer Fix or Chart
Old Dec 28, 2010 | 07:28 AM
gtrman33's Avatar
Default New Tire Size Speedometer Fix or Chart
Can anyone tell me if there is a chart to figure out the actual speed of my Jeep after installing new tires? Is this something that is a hard fix in the comp or can it be reflashed to be correct again? Thanks in advance for any help.
Old Dec 28, 2010 | 07:30 AM
wayoflife's Avatar
JK-Forum Founder
you need to get an aev procal, superchips flashqaq or hypertech to correct your speedometer.
Old Dec 28, 2010 | 08:54 AM
mbernie's Avatar
Here's a website where you can figure out the changes. There's also an iPhone app for it
http://www.mxauto.net/wheel_tire.php
Old Dec 28, 2010 | 09:15 AM
indyjeep's Avatar
+1 on the ProCal. If you just want to adjust your speedo then the Procaomp is a cheap solution. About $150 and it can also adjust your TPMS settings among a few other things.
Old Dec 28, 2010 | 09:31 AM
tslewisz's Avatar
Doesn't help with TPS reports, though.
I picked mine up used for cheap and really like it. I've reset:
- TPMS (to zero with my aftermarket wheels)
- gear ratio
- tire size
- OTLC (one touch lane change)
I think that's all.
Old Dec 28, 2010 | 09:35 AM
Mark Doiron's Avatar
Originally Posted by tslewisz
... I picked mine up used for cheap ...
Just a caution that most of these are tied to a VIN number. Some can be released by removing the modified software; some require a payment to the manufacturer to get the VIN released. Do some research on any you might chose and don't buy one that might still be tied to a VIN (such as from a sketchy source on eBay).
Old Dec 28, 2010 | 09:38 AM
tslewisz's Avatar
Right. I bought mine from a friend.
Old Dec 28, 2010 | 09:58 AM
largo's Avatar
Where is the best place to buy the ProCal?
