newb question!
I really wish I would have gone with a higher lift.. No way in hell my wife will let me buy a new suspension kit! Besides a body lift, is there anything I can do thats not to pricey, or will ruin the ride quality to get a lil higher? looking to gain about 2" (no viagra or xtend comment please... lol)
The RC 3.5 has zero adjustability. If you add coil spacers, you have no way of re-centering the axles or changing the caster for the new lift height. Depending on the size of the spacers, you will want to consider what to do with your brake lines and links, and it makes it that much more likely that you will lose driveshafts. And since you do not have adj arms, how will you set the pinion on the new shafts?
The moral of the story is : a body lift will be your 'best bang for the buck'.
a set if 2.5" up front 1.5" rear coil spacers. about $150 and your set. Get the other stuff later.
You've already got 3.5" of lift so you could go 2" front and rear spacers as well. You will have driveline problems if you add spacers and haven't changed your drivelines out yet.
how ever bigger you want to go, add spacers in that size. if theres no rake, use the same size front and rear. you may also need longer sway bar links front and rear, longer shocks, longer brake lines.. but that depends on how much bigger you go.
If you stack a 2 inch spacers on that there wont be a cheap way of doing it IMO. You will need new driveshafts, adj. tracbars, brakelines, control arms, bumpstops, breather hose extensions. Just to name some, and if you spend that much money I would just get all new coils or JKS ACOS system.
If you are doing this for the looks of a big lifted jeep then check out some flat fenders. They will give you some extra tire clearance at full flex and will give you 3"-4" of lift "look". Or for the cheap mod just trim your factory flairs.
This shot is stock suspension with bushwackers 16" rims and 33" tires.
Attachment 135501
Attachment 135501
A lot of you guys are missing the point of his original post.
