newbie needs help
Old Jan 21, 2013 | 03:47 PM
madmike232's Avatar
And I have no experience with BDS at all but I know aev is top notch. A more affordable way to go is rancho that's what I did and I love it! Rides great better then stock and love the classic white with red shock boot look.
Old Jan 22, 2013 | 01:09 PM
xshanexmurrayx's Avatar
Originally Posted by madmike232
You never "need" regear. You might want to some time to regain some pep but its not bad for your jeep or anything like people said to me. I would install the lift and wheels at the same time with 3.5 ish backspacing then save for tires and superchip ,then if you fell you need it gears.
im so confused so i dont need to regear if i go with 37s my axles wont go or stuff wont break ? hasanyone just put 37s on with a lift with out beefing everything else up ? and what is a superchip and what does that do
Old Jan 22, 2013 | 05:09 PM
madmike232's Avatar
For 37s you still need to beef up your axles, gussets ,sleeves, axle shafts exc. But gears do not make your axle stronger ... if anything it could make a week spot in your drive line if your go crazy low.
If its a mall crawler you could prob. get away with just gussets but that is bear minimal on top of finding the lightest tire you can.
Old Jan 22, 2013 | 06:06 PM
BlackRockBurner's Avatar
The bigger you go, the more you will have to spend to get a dependable rig. With 35s you will spend about $1500~$2500+ depending on what you do. 37s due to all the things that have to be replaced will cost some coin $2500~$4000+ . More money spent will be a more dependable build. You got to ask yourself, where will I wheel? Am I doing this to get to where I want to go, or is this all for show? Do your research first and be honest on what you want in the end. My suggestion before you spend and it won't cost a dime. Don't do anything to the jeep until you wheel it a few times. You will see how capable stock is, know how to pick lines. And the first money spent should be recovery gear like tow straps, d-rings, gloves, air compressor.
