Nitro Sleeves
Old Mar 21, 2014 | 12:12 PM
02604fun's Avatar
Default Nitro Sleeves
Has anyone with nitro sleeves had problems with the dia being to small I am on my second set that I can slid in with my hand
Old Mar 21, 2014 | 12:49 PM
Invest2m4's Avatar
Only time I've seen that is where someone sanded inside the axle tube a little. If you have a very accurate caliper, you could measure the sleeve.
Old Mar 21, 2014 | 05:57 PM
02604fun's Avatar
The first few inches of the tube was dirty rusted so I used some PB blaster and a wire wheel. I could even take the knurl end first and slide it all the way in and out.
Old Mar 21, 2014 | 06:08 PM
Invest2m4's Avatar
Wire wheel and PB Blaster is the right way to go. Either the sleeve diameter is bad or your axle tubes are slightly too large in diameter. Accurate measuring equipment is the easy way to get an answer.
Old Mar 22, 2014 | 05:34 AM
02604fun's Avatar
Thank you for your input,
my goal is to get the sleeves in then take the axle off the jeep and have my buddy weld my C gussetes and other misc. stuff on the front axle then I am installing new Ball joints before putting the front axle back on the jeep. its just this sleeve thing is holding up the show.
Old Mar 22, 2014 | 05:49 AM
Davesrb's Avatar
Probably not what you want to hear, but if the sleeves are a no go...try the Artec Truss. You have a friend who can weld already lined up, so its a relatively cheap mod. And the truss is stout!
Old Mar 22, 2014 | 07:17 AM
Maertz's Avatar
how loose is it, can you just plug weld it in like others?
Old Mar 22, 2014 | 01:08 PM
02604fun's Avatar
I,ve got a AEV kit so I thought a truss would be problematic
Old Mar 22, 2014 | 01:15 PM
02604fun's Avatar
I can take the knurl end and slid that in so I am guessing .015 under sized, And I really don't know where the tipping point is, I would guess the tighter the better, but I bought the nitro because that was something I could do with dry ice and prep work. Is it to loose to weld, I don't know.
Old Mar 24, 2014 | 04:14 PM
02604fun's Avatar
Thanks to everyone's input...
