Nitto Tire Weight
Old Dec 11, 2012 | 04:08 PM
rays0852's Avatar
Default Nitto Tire Weight
So I have been all over the interwebs and used the Bing machine to search for specs on some Nitto Trail M/Ts I am looking at.
295/70/18s to be exact. Nitto site has them at a hair over 34.5 inches vs my current Duratracs 275/7018 and 33.2 inches. My Duratracs are 55lbs according to Tire Rack. Only thin I could find on the Nittos was an Amazon listing that had the shipping weight at 71.6 lbs a piece!!!!! Can this be right?
Its not even a full 12.50 width tire and almost 72lbs? I'm trying to go easy on my front Dana 30 and my wallet by not going with a full 35 x 12.50, but at 72 lbs I think I will have to get a PR 44.
Anyone think this seems especially heavy for a 34.5" tire? Any others you would look at?
18" wheel.....
Old Dec 11, 2012 | 04:31 PM
Maertz's Avatar
Id say thats correct... My muds in 35 are 82lbs
Old Dec 11, 2012 | 04:32 PM
EzK's Avatar
EzK
Tire weight isn't going to damage your axles.
Old Dec 11, 2012 | 04:34 PM
Saharaunlmtd's Avatar
Nittos are notoriously heavy tires so I'd believe it. My 305/70R17 Bighorns weigh in at 64lbs and that's a 34.0" tire.
My opinion at the moment is get some 15" MB72s and a 35" KM2. I know I wish I would've now that I've realized my tires weigh 64lbs and my 17" XDs weigh 34lbs!!! I could be running a 35" combo at 80lbs instead of a 34" combo at 98lbs. Oh, and the 35s are $40 cheaper per tire.
Old Dec 11, 2012 | 04:57 PM
rays0852's Avatar
I'm sure there are a whole hot of people in this forum who would disagree. The more weight you put on the end of a steel tube....the harder it is on it....and all the moving parts connected to it.
But alas...I'm not here to get into a debate about tire weight vs axle durability. Just looking for an answer to my original question.
Old Dec 11, 2012 | 05:18 PM
beedle4's Avatar
Toyos/nittos tend to be alot heavier and most are a higher load range D/E.
My 37 toyo mt are HEAVY! But also some of the most true/round tires around.
Old Dec 11, 2012 | 05:28 PM
rays0852's Avatar
Thanks fellas....when you say true....do you also mean true to size or just very easy to balance and such?
By the way...I know KM2sand some other tires run notoriously small when mounted....how about the Nittos?
My Duratracs measure out 32.3 mounted....on a published size of 33.2 running 28-30 psi...I'd say that's pretty good.
Old Dec 11, 2012 | 06:15 PM
Maertz's Avatar
There more true to size than most and mine balanced with no more than 2 ounces. The one tire only needed 3/4 ounces of weight added...
Old Dec 11, 2012 | 07:04 PM
TheTerminator's Avatar
Plenty of people run a 35", heavy or not, on a D30 without problems. Some even run 37's. I wouldn't stress it. If you carelessly bounce on rocks, then you will break anything out there.
Old Dec 11, 2012 | 07:06 PM
How so? Every time I take off my 35" and put it back on, I can feel the strain on my body. I'm sure the vehicle feels it too.
