non rubi D44 upgrades for 37's
so I have 07 x 2dr
I want to run 5:13 gears fully locked down the road....
For the rear axle what upgrades should be done?
As far as strengthening the rear shafts....what is need for 37's?
cro-mo stock replacements shafts (30 spline)?
32 spline (do they even make these for non rubi?)
or 35 splines?
if the consensus is go with cro-mo 35 splines....what ARB locker part# is needed to work with those shafts in my non rubi rear D44?
or 35 splines?
35sp locker + 35sp shafts
or
30sp locker + 30sp shaft + stock shafts as spares
(in case you bend a flange and have to send them in and wait for warranty replacements)
I went with a 30sp locker with stock shafts for now. I'll upgrade to alloy shafts in the near future when I decide which to buy. The price on the G2's looks good, but Ten Factory ...
or
For the front I plan on the new g2 core 44 axle assembly or a pro rock 44.
Im asking about the 30spline cromo shafts vs 35 spline versions because if the 35 spline are very unlikely to fail with a 37" tire. Ill save up and go that route.
If they can break like the 30 spline just not as often. I think ill go with the 30 spline...keep my stocks as spares.
That also lets me upgrade the rear in stages....ie first the shafts then the locker ect.
