Now what.. rear swaybar issue..
This past weekend I helped my friend install his rk 3.5 max lift on his 2dr.. so part of the install was to move the rear swaybar back one inch. This kept the links straight. So I looked at mine and my links have been quite pointed forward for a while... So it clicked.. I needed to move mine back to make the links straight up n down. So what I did was remove both mount bolts on both sides and move the whole thing back so the front hole now goes into the rear frame hole. I drilled and tapped the new hole for back mount. Links are perfectly up and down now. But I have two new issues. And all issues are on rt side except how close the links are to the tire sidewall.. the pass link is right in the center of the frame trackbar bracket and there is maybe 1/16" clearance between the link nut and bracket. Also the links are about 3/4" from sidewall..
So what should I do.?? Do I move the bar forward, do I move it back more to clear the trackbar bracket?? Should I get new wheels with less bs?? I flexed it and when the rr is stuffed the link just kisses the tire sidewall.
Help from experienced ppl is greatly needed. Thanks.
JK-Forum Founder
looks to me like you're either running factory wheels or wheels with too much backspacing. wheel spacers and or new wheels with 4.5" of back spacing or less should fix the sidewall contact issue. also, if you are seeing this problem only on one side, your axle is most likely not centered. if you don't already have one, you need an adjustable track bar to help correct this.
Yes factory wheels with spidertrax ..
The links are the northridge links.
Other issue is if I run the bottom link on the outside it hits the caliper when flexing lightly.. So bottoms are on inside and uppers are outiside because I feel better and it looks better with the top outside also cause the link is smooth and round on that side.
I also have eve rock stars.
Judging from this pic, you might be able to flip the sway bar link to the other side of the sway bar arm? ...if that makes sense? I could have sworn I read of this being suggested somewhere else?
I am not really experienced but just a dumb question. Did you put a rear track bar extender bracket in??? My kit didn't come with one and I had to order it. I noticed that my sway bar was really close and then read about needing the bracket. Once I put it in it was fine!
