NSG370 Rattle Sound at higher rpm solved, but what is this part?
Old 04-20-2017, 08:02 PM
sundevil's Avatar
Default NSG370 Rattle Sound at higher rpm solved, but what is this part?
So I have been getting some type of rattle for a long time from my transmission in gears 2, 4, 6 and I popped the cover for the shifter boot and found this.
I have found the outer boot but can't locate this inner one. Seems to put tension on the stick so that the stick doesn't move around freely.
Thanks
Old 04-20-2017, 10:55 PM
Ajkaz's Avatar
The newer boots dont seem to cause the shifter issue, they also isolate heat and sound well.
https://www.moparpartsoverstock.com/...2060165AE.html
Quick Reply: NSG370 Rattle Sound at higher rpm solved, but what is this part?
