Off road jack mount prototype
Old 02-04-2014, 03:32 AM
JDSjku's Avatar
Here's a couple pics of prototype jack mount. Mounts fasten to roll cage with collars on each side. Click image for larger version
ID:	528678 Base mount Click image for larger version
ID:	528682 Handle mount Click image for larger version
ID:	528680 Base mount Click image for larger version
ID:	528685 Handle mount
ID:	528679   Click image for larger version
Old 02-04-2014, 04:50 AM
dalford4214's Avatar
Looks cool!
Rebar-7's Avatar
Interesting, like to see when mounted with jack. !
Old 02-04-2014, 05:29 AM
HardRooster's Avatar
I think you might want a piece of 3/16" plate (Looks like you have 1/8") if the jack is to be mounted horizontally. Vertically it looks like it would be good.
Old 02-04-2014, 08:15 AM
JDSjku's Avatar
3/16 plate here is couple more pics.
Old 02-04-2014, 08:17 AM
JDSjku's Avatar
Mounted horizontally
Old 02-04-2014, 08:46 AM
ZoidMax's Avatar
Good idea.
You could also use all thread with a wing nut to clamp it tight then a cotter pin behind that? Just a thought if you are looking for different ideas.
Old 02-04-2014, 03:04 PM
jeepmojo's Avatar
Default isnt a little bottle jack just as efficiant ?
i mean thats a lot of extra weight to be just sitting there never getting used ??? i like the looks but they should make a stong light weight one for us ! i know they work well but not used for the most part
Old 02-04-2014, 05:45 PM
JDSjku's Avatar
Bottle would never work. Will not get tire off the ground. Also jack is not just used to lift jeep up either has several other uses when needed. Bottle junk when jeep is lifted higher then max bottle extension.
Old 02-04-2014, 05:47 PM
JDSjku's Avatar
Need mount built because I have trex top which is frameless. All other mounts are in the way of top.
Quick Reply: Off road jack mount prototype
