Offset Balljoints?
Went and got an alignament today....
Was told they could not completely align due to bent axle and that I needed
Offset ball joints. They got it as close as they could for me.
They were not pressuring me to get these, but did quote $120 for the Balljoints, and a total of $620 parts and labor.
Has anyone had this problem and did Offset Ball joints work?
What should I do to prevent any long term problems also?
Place a jack stand under the axle next to the jack.
Lower to put some weight on the jack stand.
Place a long pry bar under the tire.
Have someone pry the tire up and down while you watch the lower ball joint for up and down play.
Axial (up and down) movement in the lower ball joint should not exceed 0.050"
Have someone grab the tire at top and bottom to wiggle the top in and out while you watch the upper joint for side play.
Radial (side-to-side) movement in the upper ball joint should not exceed 0.060"
Even if the upper joint checks good, change both if the lower checks bad.
