Offset Balljoints?
Old Apr 1, 2010 | 07:38 AM
you are supose to check the complete front end before doing an alignment. most shopa do.
Old Apr 1, 2010 | 08:27 AM
Ryanc's Avatar
Your camber specs are not that bad. Mine straight from the factory was 0.9/0.8. I am sure someone will dispute this with me, but I have hunch that many of these axles are coming from the factory like this. The guy that has worked with me in adjusting my castor stated that I could get some adjustable ball joints if I wanted, but it was not necessary. He stated to look at my tire wear, and if you notice anything crazy consider putting them in.
Old Apr 1, 2010 | 08:36 AM
Hellbound13's Avatar
My specs are .3 and .4 with fresh ball joints. Those specs seem off.
Old Apr 1, 2010 | 11:06 AM
chumpmann's Avatar
Yes my tire wear was the reason I got it done.
Would JUST bad ball joints get the alignment that out of whack?
So that all I would need to do is just replace stock?
Or are they bad enough that I should get the offset Balljoints?
Old Apr 1, 2010 | 11:19 AM
ronjenx's Avatar
It would be good to know how much play your current ball joints have before you spend the money on the offsets..
Mine are worn to 0.015" vertical play. The limit is 0.050". My right camber is at -0.7°, just a tad outside the limit. Caused by slightly worn ball joints?
Some people's joints have been worn enough to throw the alignment out.
Anyway, see what you have for wear, and make a decision from there.
Old Apr 1, 2010 | 11:46 AM
jeepsanddrums's Avatar
What did you use to measure 0.015" vertical play?
Old Apr 1, 2010 | 11:55 AM
ronjenx's Avatar
A dial indicator with a magnetic base.
A google search will bring up lots of them, from cheap to expensive.
Old Apr 1, 2010 | 12:42 PM
Castalone's Avatar
X2. 09' ceck complete jeep every time I go out on a rack, no play. Toe causes much more tire wear then camber. Cars go around fine with -2.0 degrees camber... I can live with one, my tire wear is even
Old Apr 1, 2010 | 01:29 PM
chumpmann's Avatar
Ok, I will take it in to have it looked at, and they should be able to tell If I Just need to replace the stock ones, or if I am bent to go with the offset ones....right
Old Apr 1, 2010 | 02:22 PM
Brashanic's Avatar
my camber is similar to yours. but it has pretty much been that way since it was new. my ball joints were ok. if you hammer the thing off road a lot just save the money on the offsets and wait until it is really bent then buy a new dynatrac. that's what i'm gonna do
