Is Ok to run with out the front driveshaft ?
Old Mar 30, 2013 | 01:36 PM
RKracing's Avatar
Default Is Ok to run with out the front driveshaft ?
Is Ok to run with out the front driveshaft for a few weeks? I just lifted our Jeep and the front driveshaft looks to be in to much of a angle. I am ordering a new one asap.
But in the mean time it LOOKS like it might be better to run with out it for a few weeks if nothing will slide out of it's place with out the driveshaft not being there.
Thanks for your advice, Robert.
Old Mar 30, 2013 | 01:38 PM
tcdawg's Avatar
No problem
Old Mar 30, 2013 | 01:41 PM
ryanawall's Avatar
Ran without mine for months. Just don't put yourself in a situation where you will need 4wd.
aldaman's Avatar
You'll be fine w/out running one. Others have taken them out to:
-Help with gas mileage (slightly)
-Have too much vibes due to a high lift & can't quite dial in the suspension to stop it and only install it when offroading
-When doing long distance driving
-When the stock goes bad and don't have a replacement available.
Old Mar 30, 2013 | 03:20 PM
RKracing's Avatar
Thank you everybody, Thanks big time.
