OME Flighty Steering Help
I have the OME HD kit, and am experiencing flighty/wandering steering.
Had my Jeep aligned and here are the specs
Left Right
Camber -1.1* 0.1*
Caster 1.3* 1.0*
Toe 0.07* 0.09*
What should I fix, and how? (Control arms, camber bolts?)
Left Right
Camber -1.1* 0.1*
Caster 1.3* 1.0*
Toe 0.07* 0.09*
David, I love my OME HD lift with the FT trackbars. Many thanks.
I'll be installing the FT upper control arms you sent me and I'll give you guys a report on it later this week.
Also, I'm going to order the rear driveshaft for my 2 door, should I order just the rear FT upper adjustable arms or both upper and lower to set the pinion angle properly?
And the driveshaft, any real reasons not to go with a 1310 OE flange model?
FT,Currie, Clayton or Tera all make nice control arms .
You only need the Uppers to adjust pinion angle. Lowers are usually used to set your wheelbase back to normal after a lift.
No there is nothing wrong with the OE flange model.
David
David
Can putting in upper control arms to set my caster give me driveline vibrations?
The more castor the better IMHO approx around 5-7 but if you have driveline vibrations you need to go with less castor. It really needs fine tuning. Some jeeps can handle 7 degrees of castor . Mine could not becuase I had to much vibration front driveshaft so I am running approx 5 degrees castor.
Hope that helps.
David
