OME Install in-progress. Thoughts and pics included
I am installing mine this weekend.
I just ordered the OME from David. If you use the HD front and standard rear spring, you don't need to add the trackbars (according to David), it's a straight swap.
David
Hey FourEyes45/somewhereinla/Schantin/others:
when you guys get time, maybe post up & revive the show your OME thread.
It would be nice to see some new rigs.
Had a week to test the suspension on and off-road now.
On-road - Much better drivability than stock. The ride is form but smooth and soaks up bumps well. Lateral movement around turns/curves is unchanged, even though the Jeep is lifted. Road feedback through the steering wheel is improved (which I found suprising)
Off-road - Took the Jeep into the Va mountains (thanks to 8" of fresh snow). The Jeep was very controlled. I had the Jeep tilted up to 20 degrees laterally going around some obstacles and never felt like it was going to roll. I cleared 2x trees that had fallen down (about 18" in diameter each) with no difficulty. I had 2x adults and 3x kids in the car when wheeling.
One other thing I learned: Be sure to measure everything when installing this lift kit (twice). When I origonally finished the install....the driver side front was 1" higher than the passanger side front.
Took the systematic approach: Found that the passenger side front tire was at 25PSI (Driver side-was at 33PSI). Filled both tires to 37PSI.... and gained 1/4" lift on the passenger side. Remeasured both swaybar endlinks. I realized I had a bad measurement on the passenger link. Lengthened that link to match the driver-side (within 1/16") - gained another 1/2" on the passenger side.
So....2x stupid little things and I made up 3/4" of "difference" concerning my post-lift lean. As for the last 1/4" difference....... couldn't figure it out. Everything was identical when the Jeep was on jacks. Went wheeling all day..... now it sits level.
Guess it needed to settle.......
In conclusion: Measure everything 2x, get some aftermarket endlinks, and enjoy a great suspension
Oh, final lift gains were 3 5/8" front and 3 1/8" rear.
Took the systematic approach: Found that the passenger side front tire was at 25PSI (Driver side-was at 33PSI). Filled both tires to 37PSI.... and gained 1/4" lift on the passenger side. Remeasured both swaybar endlinks. I realized I had a bad measurement on the passenger link. Lengthened that link to match the driver-side (within 1/16") - gained another 1/2" on the passenger side.So....2x stupid little things and I made up 3/4" of "difference" concerning my post-lift lean. As for the last 1/4" difference....... couldn't figure it out. Everything was identical when the Jeep was on jacks. Went wheeling all day..... now it sits level.
Guess it needed to settle.......In conclusion: Measure everything 2x, get some aftermarket endlinks, and enjoy a great suspension
Nice writeup. I installed the OME 2" lift about a year ago and I just finished upgrading it with the OME long travel shocks and a set of lower control arms for increased articulation. See my thread: https://www.jk-forum.com/forums/jk-show-tell-33/ome-2-lift-long-travel-shocks-lower-control-arms-75302/
Before (OME 2" lift):
After (OME 2" lift with Long Travel Shocks, Teraflex Lower Control Arms Fr and Rear):
Doesn't look like much but that is a hell of a lot more flex. It is also smoother offroad and handles better on road especially when trying to keep her straight on the highway.
