OME Lift w/ 37"
Old 10-02-2012, 05:22 PM
whiterave's Avatar
Default OME Lift w/ 37"
I was looking at getting a 2" lift ome and was wondering if that would work ok for 37" tires? Or would I need additional lift somewhere?
Whiterave
Old 10-02-2012, 05:28 PM
FoxRacingJMC's Avatar
You're going to need a lot more than just a lift to run 37's bud. 2" won't even work unless there is some new way or lift that can. A lot more goes into running 37's other than lift height....
Old 10-02-2012, 06:07 PM
Tonka_yellow's Avatar
Whiterave
You can put 37s on your jeep but you will
-rub the fenders if you don't bumpstop
-rub the sway bar if you don't steering stop it
-break or bend something in the front end if you don't build it
-you might need to regear if you don't have a 2012/2013 and 4.10
If you drive it on the street then sure it will probably last. To have us better answer your question... What year and model do you have.. also will you wheel it
Old 10-02-2012, 06:18 PM
whiterave's Avatar
I know I will need more equipment I am just talking about the lift, I want to build it up in stages I will run it with 35" for a while then go to 37" I just want to buy my lift once if possible
Old 10-02-2012, 06:46 PM
JK Forum Regional Rep
BigLow's Avatar
I started out with a 2" HD OME lift. It was awesome with stock sized tires.
Once I put on only 35s and started to wheel it frequently I found there are a lot of additions that are needed because I rubbed on everything. In the end mine turned out to be a ~3.5" lift with extended bumpstops, spacers, OME long travel shocks, wheel spacers, brake lines, and cut fenders. New Trackbars, CAs, and DS helped too. As you can see I only still use the coils, but even those have a spacer. Now the system is complete the ride and flex are good. What I'm getting at is, if you go this route plan to part your own lift together if you want it to wheel right.
If I did it again, I would get a complete kit with my final tire size in mind.
Old 10-02-2012, 07:49 PM
JonP's Avatar
WIth a 1inch body lift and flat fenders you might fit and work just fine.
Steering stops and bump stops will be required
Or
Take a look at their 4 inch kit and flat fenders. More complete kit. Excellent ride
Old 10-03-2012, 12:52 PM
Ryan0260's Avatar
Just get the OME 4" lift....
Old 10-04-2012, 08:49 PM
whiterave's Avatar
I just saw that they have a 4" lift is that new? Has anyone used it? Is that to much lift for 35s"
Old 10-04-2012, 09:53 PM
crazyhorse02's Avatar
I have the OME 2" HD lift w/ a 1" BL and flats and I'm going to 37's in the near future. Look up *******'s write up of a similar combo.
Old 10-05-2012, 09:18 AM
Chicofof's Avatar
With that ome 2" kit...is there anything else you needed to change... Or is that kit complete?...(08 4dr Sahara un/33's)??
Quick Reply: OME Lift w/ 37"
