Opinions on my bent axle
Old 03-24-2018, 05:19 AM
DKehler's Avatar
Default Opinions on my bent axle
My axle is slightly bent. There's no vibration or pulling. Is it minor enough that I can truss it ( to prevent further bending ) and call it good?
Old 03-24-2018, 05:49 AM
jadmt's Avatar
My new 2018 recon came from the factory at -9* on one side. I see a lot with high camber right out of the chute.
DKehler (03-24-2018)
Old 03-24-2018, 05:52 PM
resharp001's Avatar
Received 1,827 Likes on 1,597 Posts
Did you do something that makes you THINK you bent it, or are you going just by the alignment alone? You jumping sand dunes baja style? Do you still have factory ball joints?
Old 03-25-2018, 08:41 AM
BoraBora's Avatar
Your axle isn't bent. In fact that alignment readout doesn't even really surprise me.
My camber was at like -1.8 on my driver side. My lower ball joint was also shot (F*ck Teraflex, what a load of garbage).
I really wouldn't worry about it, your C is either slightly bent or your ball joint is going out/is toast. If its over -3 degrees, then I honestly...still wouldn't worry about it. Over -4 then sure, you can worry. A lot of BMW guys actually like running -3 degrees(ish) because they can corner better
Do a ball joint test. If your ball joints are fine, then just keep driving it and maybe rotate your tires every 3k miles instead of 5k (or whatever your current interval is).
DKehler (03-25-2018)
Old 03-25-2018, 08:48 AM
BoraBora's Avatar
Here ya go, this is what my alignment readout looked like when my driver side lower bj blew. Also yeah, my rear flanges are bent again, ignore that
Old 03-25-2018, 02:08 PM
DKehler's Avatar
I've replaced my ball joints a couple times. I just checked them again and they're good. I recently needed a lot of momentum to climb a sand dune. I was focused so much on the dune I missed the ruts at the bottom of it and caught a little air. Maybe a foot. That's what urged me to get the alignment checked.
Quick Reply: Opinions on my bent axle
