overheating
Old Jul 26, 2011 | 07:37 AM
j33p4life's Avatar
Originally Posted by Roaddog545
is your temperature gauge working correctly? I had a similar problem and replaced the temp sending unit and it cured it. It was not allowing my fans to come on and was overheating at slow speeds. It was ok at driving speed. Plenty of air flow there.
that's how it seem with me! driving speeds are fine but slow is bad. how would I know if it is working correctly? just replace it?
Old Jul 26, 2011 | 07:43 AM
Yankee's Avatar
Your fan should be audible inside the Jeep if the engine temp is getting hot while going slow. Mine is pretty loud when on the high speed setting.
Can you hear your fan running when this condition occurs?
Old Jul 26, 2011 | 07:58 AM
Vic's Avatar
Vic
Originally Posted by j33p4life
ok so the tranny cooler will help the hotoil light. and then what should I do about the coolant temp?
Some time the tranny being so hot heats up the engine as well. Get the tranny cooler that should eliminate any over heating paased to the engine. If engine still heating up after tranny cooler check your radiator termostat, water pump.
But I think Tranny cooler woud get the kob done.
Old Jul 26, 2011 | 08:11 AM
j33p4life's Avatar
a local shop told me to service the tranny? could that be it? they said te fan nay be going out also.
Old Jul 26, 2011 | 10:33 AM
Yankee's Avatar
Don't know what they mean by the fan "may be going out"
While there may be other issues, your vehicle will overheat at low speeds in hot weather if the radiator fan does not work.
So....does your fan work? You can easily tell if the fan is working. Let it idle long enough on a hot day, it should kick on. Also runs when you have the AC or defrost on. There is a low and high speed. Before your temp guage is getting to 3/4 (if that is what your seeing) the fan should be running at high speed.
As far as the tranny, if it shifts okay, the fluid is full and not burned, and you don't have 12k or more on the last fluid change, not sure what they want to service.
But I would put a tranny cooler on (or have someone do it) if your going to crawl in 90+ weather. Cheap insurance to avoid a lot bigger bill (or possible fire). The autos should have come with a real tranny cooler in the first place.
Sounds like two different issues....engine coolant temp and tranny temp?
Also, if you were playing in mud....as stated before make sure the radiator is clear of it.
Old Jul 26, 2011 | 11:10 AM
j33p4life's Avatar
ok thanks! i just asked the shop their price for a tranny cooler and they said that those might be issues. so I think I will just go with a tranny cooler and hope that helps! thanks a ton!
Old Jul 26, 2011 | 02:47 PM
seer1's Avatar
It's best to shift into 4 lo almost as soon as you leave the pavement. The JK doesn't like low speeds up and down hills in 2x or 4 hi.
Old Jul 26, 2011 | 04:08 PM
daspes's Avatar
X2. The 231/241J's do not like to spend a lot of time in 4-hi.
Old Jul 27, 2011 | 08:11 AM
j33p4life's Avatar
ok thanks everyone your help!
