Paint question
Old Mar 12, 2011 | 05:48 PM
w3asel's Avatar
Default Paint question
I'm getting a set of Rugged Ridge Mirror relocation brackets. They are gloss black. I would like them to be flat black. Will prepping the existing paint with a Scotch Brite pad before applying aerosol automotive paint be enough? What's the best way to do this. Thanks for any budget minded help.
Old Mar 12, 2011 | 06:15 PM
zeppo's Avatar
Scuffing the surface of the existing paint is all the prep you'll need if it's in good shape, which it is since it's new. I'd do it with a fine grit sand paper to get the best adhesion for the new paint layer.
Old Mar 12, 2011 | 06:22 PM
DeJK21's Avatar
i have to do the same, i got used ones from a friend who has a burnt orange jeep and he painted them the same color so i need to paint back to black, ill post a picture when i'm finished
Old Mar 12, 2011 | 06:35 PM
Harbourone's Avatar
Wipe with a degreaser to remove oils before spraying and you're spot on.
Old May 8, 2011 | 05:28 PM
jpthunder's Avatar
I painted my windshield light mounts that were also powder coated black. I sanded and then did a few coats of red and few coats of clear sanding in between and buffing the final coat as well. I am happy with the final product, but I wish I had primed them first though because it has chipped a little underneath (can't be seen without some serious inspection). Put the extra work in initially and you will be happier in the long run, better to do it right the first time. Good luck and post some pics when you're done, I'm thinking about doing this one too.
Old May 8, 2011 | 05:31 PM
jpthunder's Avatar
Oh, I used the duplicolor spray can stuff and it was a perfect match, tons of questions and compliments.
