Painting Inside Hardtop Black?
Many of us have done this over the years with good results. Here is one from way back in 2007 using spray cans of duplicolor bedliner.
https://www.jk-forum.com/forums/jk-w...d-liner-19277/
Did mine late 08 I think, don't really remember since it was so long ago. Chose bedlner over paint because it was a dull, non-shiny black. I rarely run the hard top, but no issues doing the inside with the bedliner. And easy touchups if needed.
Yup, when I had a hard top, I painted the inside and had no troubles. The key, as others have said, is to let it completely dry. Not only for durability but because of the vapors. You wouldn't want that smell getting into your vehicle upholstery let alone you breathing it.
I had my hard top painted with an automotive vinyl matte black paint applied with a gun.
it looks Looks great.
I tried to use dynamat under the headliners but it melted from the heat of the sun especially on the large headline covering the trunk area.
I ended up removing the dynamat and reinstalled the headliner. I have been happy since.
Make sure the top is 100% completely cleaned prior to installation or you may find the double sided tape will let go from gravity.
//D
What it DID do was making a darker feeling inside so reading stuff meant turning on the dome light more often.
