Pinion angle
Old Jul 5, 2012 | 10:45 AM
laughrun's Avatar
Thanks guys. I'm going to try to adjust it this Sunday. I will have put about 800 miles on it the way it is by then. Hope it doesn't mess anything up. It's not a bad vibration at all. I bet if someone else drove the jeep they wouldn't even notice.
Old Jul 5, 2012 | 11:20 AM
DanieltheManual's Avatar
The shaft will still 'feel ' different than stock due to design, might wurrrr a bit ...might not.
Old Jul 5, 2012 | 11:24 AM
Rock Krawler Suspension's Avatar
Former Vendor
Originally Posted by GunDude
Yes, but seems like I read perfect is 1-2 degrees below. I would say put it inline and see how it feels from where you have it now either leave it or move it back.
1-2 degrees below straight on with the driveshaft is normally where we would set the pinion angle, at 4"-4.5" of lift have you checked your front driveshaft and pinion angle?
RK
Old Jul 5, 2012 | 11:43 AM
laughrun's Avatar
Yes I have. I'll put a pic up of the front later. Is 1-2 degrees below straight better then straight? And I thought these shafts might vibrate a little more cause of design. Like for one their isn't that isolated thing on the yoke on the transfer case like stock.
Old Jul 5, 2012 | 11:45 AM
laughrun's Avatar
Also I think "a wurrr" describes the feeling. Starts after about 55mph. It's doesn't really get worse as you go faster then 55 though.
Old Jul 5, 2012 | 11:54 AM
bigapplephx's Avatar
Default Driveshaft Angles
RK
On my 09 JKU Rubicon, I have installed your RK Mid arm Flex 3.5" lift. My Woods driveshaft is a "little" below straight. I have no vibration yet. Where do I measure to get the amount of degrees it is off?? If I need to adjust a small amount (1-2 degrees) can I use the lower control arms? Thanks for your help..RockKrawler is a great lift.
Old Jul 5, 2012 | 02:15 PM
GunDude's Avatar
I believe you put an angle finder on the DS and note what angle it is at, then put the angle finder on the yoke and note the angle it is at. If both are same then DS and pinion are inline. Then put angle finder on yoke and you can adj. the lower control arms back to bring angle down. I believe this is how it is done but not positive! Still have to install mine, but hoping to hold out till I have new gears put in next summer!
Old Jul 5, 2012 | 05:53 PM
laughrun's Avatar
Here is a pic of the front. Looks good to me
Old Jul 5, 2012 | 06:28 PM
keithvegas's Avatar
Hard to tell from that pic but it looks like negative caster. The front should be set to caster angle not pinion angle.
Old Jul 5, 2012 | 06:53 PM
laughrun's Avatar
I agree, it's not that bad. Just was a bad angle I took it at. I was mainly showing that because RK was asking cause of the vibration I was talking about.
