plastic rivets on the fenders?
ok How do you get the plastic rivets off on the fender
. they hold the liner and fender together it looks like . and one is holdering the side marker. I do not see how they come off. I have tried pushing the center, pulling , everything short of just braking it off. but I don't want to because I may need them later . any fast help thanks, John
It takes a special rivet gun You will have to buy it from the dealer $59.00 the rivets will not fit in a normal gun. Or you will have to buy some kind of after market rivets for the normal gun if they make um..
I found some black plastic rivet type screws at Home depot. They match pretty good. Instead of a rivet they have a phillips screw in the center. Take one of the drilled ones with you if you go this route because they had alot of different sizes.
At work I use a stiff & narrow putty knife that is razor sharp and a hammer to chop them off without marring the flare. Then I use a Spitzenagel limited access plastic pop rivet gun to install the new ones.
