Plastidip/ Rustoleum Rubber Coating..
Originally Posted by Nkrimmel2012
I guess I can go back over it and fix it later...
I use Plasidip for applications that I might want to peel off later or that I need to be flexible. I use Rustolium Bed Liner for applications I need to be more durable and that I'm banking on being more permanent.
I Plastidip'ed my antenna for looks, but when I reinstalled it to the receiver, the Plastidip peeled away when I lightly used a wrench to tighten it down. I later removed the antenna and redid just the bottom with the Rustolium Bed Liner. I was able to screw it down tightly and the Bed Liner didn't peel away.
Hmmm really... I need some mineral spirits for some minor over spray.. but yea the side I did that's not that great is pretty thick, so you say, soak it in mineral spirits and scrape at it with a plastic putty knife, and try to reapply
