Please help !!! Esp BAS lights on. No reason
Old Sep 23, 2011 | 10:22 AM
Bxjk's Avatar
Ok. Great. I called the stealership already and they gave me a bogus excuse that my tires probably spun in the rain. Little did they know I drove to work early enough to avoid any rain. So I will hound them on Monday and bring it in.
Old Sep 25, 2011 | 05:08 PM
Bxjk's Avatar
Re-centered steering wheel and lights are still on. Have to make an appointment to bring it in this week.
Old Sep 25, 2011 | 06:24 PM
Vin's Avatar
Vin
Did you try disconnecting the battery for a few minutes and reconnecting? Mine ABS ESP and BAS lights went on Monday. I found I had a bolt loose on my rear control arm so I tightend it down. I also had some work to do on my dual battery set up so I disconnected my batteries. When I reconnected, the lights were off. I've driven a few miles with no lights/issues. I'll see if they liht up again during the week.
Old Sep 26, 2011 | 06:22 AM
Bxjk's Avatar
Funny thing happened. Driving to work today the lights went off. But on a turn doing maybe 20mph the ESP light came on and I felt a little shutter in the front end.
Thinking maybe my axle came off center or needs to be tightened up. What a pain in the a**
any input?
Thanks again guys
Old Sep 26, 2011 | 06:39 AM
Jknockers's Avatar
Mine did the same thing yesterday while out wheelin. Also when on the trail the left rear caliper was clamping down and was makin a shutterin noise. I stopped and checked the rear wheels, touched rear calipers, left hot, right cool. All day long it would lights on and off. I reset codes aired up tires and again light came on. I will disconnect battery, and hope for the best. I wonder if this is a timed programmed thing since all of us all of a sudden on the same day for no reason had this happen???????
Old Sep 26, 2011 | 07:57 AM
Yankee's Avatar
Originally Posted by Jknockers
Mine did the same thing yesterday while out wheelin. Also when on the trail the left rear caliper was clamping down and was makin a shutterin noise. I stopped and checked the rear wheels, touched rear calipers, Right hot, left cool. All day long it would lights on and off. I reset codes aired up tires and again light came on. I will disconnect battery, and hope for the best. I wonder if this is a timed programmed thing since all of us all of a sudden on the same day for no reason had this happen???????
Makes me wonder if it might be the wheel sensor or wire, if everything like the suspension is good and steering wheel centered.
Old Sep 26, 2011 | 08:54 AM
Jknockers's Avatar
I agree with ya, will dig into it and post back what I find. Gonna take out sensor and clean (both left and right rear sensors and check connections).
Old Sep 26, 2011 | 09:04 AM
Bxjk's Avatar
Sorry for the newbie response but if you take your sensor out can you post a pic
Old Sep 26, 2011 | 02:02 PM
Bxjk's Avatar
Awesome. I really appreciate the pic.
Awesome shocks
