polling question on gearing with 35's
Old Nov 29, 2009 | 11:15 PM
09RubiconUnlimited's Avatar
Default polling question on gearing with 35's
I will be installing the 4.5 rubicon express lift with 35 inch tires. I would like to see what others have changed the gearing to with that tire configuration if any at all. how do you like the new gearing that you used.
thanks for any help.
jk is 09 Rubicon Unlimited
Old Nov 29, 2009 | 11:25 PM
BlackNorthernJK's Avatar
belongs in modified forum.
I would say this is probably the single most talked about subject and you can find a TON of threads in modified to help you answer your question
Old Dec 1, 2009 | 02:31 PM
spinlock's Avatar
Well since the powers that be haven't moved this thread, I will contribute.
Read the FAQ in the Modified Forum, it contains all the guidelines.
Search for a thread titled Gears, Gears, Gears and find Planman's post it contains some excellent information on how to make your selection,
plus that thread has many opinions and informal polling information.
The general consensus is 5.13 if you are running an auto, and if you must you can get away with a notch or two less if you have the manual.
Old Dec 1, 2009 | 03:25 PM
rubious's Avatar
like spinlock said.
from what i've read its 4.88's manual
or 5.13's on an auto
extreme??
Old Dec 1, 2009 | 03:52 PM
RN M OVR's Avatar
Originally Posted by rubious
like spinlock said.
extreme??
x2. When/If I go 35's I will do 5.13 gears.
Old Dec 1, 2009 | 04:38 PM
nthinuf's Avatar
If I had a Rubicon, I would have gone with 5.38's in a heartbeat. But since I made a poor decision and got a Sahara instead, 5.13's will work...
Old Dec 1, 2009 | 04:41 PM
nangulator's Avatar
I have an auto with 35s and a set of 5.13s sitting under my tool box waiting fo me to put them in.
Old Dec 1, 2009 | 04:44 PM
put 'em in already
