Popping noise after diveshaft install
Old Feb 15, 2012 | 08:37 AM
medic_23387's Avatar
Default Popping noise after diveshaft install
I installed new front and rear drive shafts the other day. Now when I am coming to a stop I get this loud pop. It sounds like a wrench hitting the frame like metal on metal. When it is in 4wd it pops a lot any ideas
Old Feb 15, 2012 | 08:57 AM
wayoflife's Avatar
JK-Forum Founder
is it just a single "pop" or a series of pops like something rotational making contact with something?
Old Feb 15, 2012 | 09:05 AM
A single pop while coming to a stop. When in 4wd and under load like crawling up a ledge it will pop multiple times
Old Feb 15, 2012 | 09:11 AM
Rich6700's Avatar
Did you replace with factory shafts or after market?
Old Feb 15, 2012 | 09:46 AM
Yeah je reels from northridge
Old Feb 15, 2012 | 09:48 AM
Northridge4x4's Avatar
Sponsoring Vendor
Are you sure you torqued the pinion nut properly ? I am wondering if the noise you are hearing is the pinion moving a little bit.
David
Old Feb 15, 2012 | 09:49 AM
I torque the pinion nuts to 160 lbs
Old Feb 15, 2012 | 09:51 AM
The dust shield on the pinion in the front is loose it didnt fit well. The dust shield does not turn with the yoke.
Old Feb 15, 2012 | 10:05 AM
Rich6700's Avatar
You don't have the yokes tight enough. Pull the shafts tighten the yokes tighter so there is no play, then back the nut off then re-torque it.
Old Feb 15, 2012 | 10:14 AM
There is no play if you try and move them by hand how tight is tight enough???
