Possible Wheel Sensor Issue
I have a 2012 JKU-R. I had a problem with my ESC coming on, and then my ABS. After a few days my Hill Descent started kicking in, as well. I diagnosed the wheel sensor and changed it. It seemed to fix it. That was three weeks ago and now the ESC and ABS lights are back on and it seems to be dragging on the left again. Any ideas at what to look at next?
If it has generated a code, an ABS / advance code reader should be able to tell you if it is the same wheel.
Assuming it is the same wheel:
Check that the wiring you just changed is connected, try some contact cleaner/abrasive on the connector to remove corrosion.
Check the tone ring is not damaged.
Try another sensor
Then burn it with fire.
Try another sensor
I too would put your chances of a bad unit bearing very high. Put the Jeep up on jack stands and spin the wheels, check for drag and noise and give those suckers the ole shake test. Any clucks, play or grinding is a sure sign of a wheel bearing and that will trip up your traction control system.
