Power source (keyed)
Hey guy's, this may be the wrong place to ask this but is there a 12volt keyed power source to use for powering a relay via a switch. The reason I ask is my 98 TJ had 2 of them, 1- 3 amp and 1- 10 amp, both were located behind the glove box. It would be great if the JK had this too, I'm getting ready to put a set of KC fogs on my bumper. Thanks in advance for any info.
Wheelerbob
Wheelerbob
Why not wire it via KC's instructions and go directly to the battery? The harness will come prewired with a 25A inline fuse for the relay and a 3A inline fuse for the signal on the switch. If you want to tap into a keyed source, the "seat heaters" fuse in the main fuse box in the engine compartment is switched.
