powerplant question
We have the Warn Power Plant HP. I believe it is built for vehicles like the Jeep. The HD is for large vehicles like trucks and is more than you will probably need for normal use. Also, it doesn't fit as many Jeep bumpers as the HP. We've used it on another Jeep pulling a ZJ up a high embankment and over the top. It worked real smooth and I am very happy with this choice.
What makes you think they are different sizes?
Looking at the Warn web site it appears the only difference between the HP and HD is the Gear Ratio. With the HD gear ratio you can theoretically pull more, using less current, but not as fast as the HP. The HP also comes with more/thinner wire rope.
Looking at the Warn web site it appears the only difference between the HP and HD is the Gear Ratio. With the HD gear ratio you can theoretically pull more, using less current, but not as fast as the HP. The HP also comes with more/thinner wire rope.Trending Topics
I got the HD (from Norrthridge4x4) because of the power usage (easier on the battery/electrical system), and the potential extra pulling power. The only drawback for me was the shorter cable length - but I’m planning to use synthetic, so I can still get 125’ and pull 12,000 pounds.
