Premature bushing failure with mk or aev?
If by mk you mean metal cloak they along with aev are higher end companies that use high quality parts. I've never heard of either causing any bushing issues. If everything is installed correctly you would have nothing to worry about. I'm running an aev lift and love every bit of it.
AEV uses stock control arms, so no bushings issue there.
They also use factory trackbars front and rear with factory bushings, so again, no issues there.
Sent from some string and a few tin cans.
Mk = metal cloak. I have heard the mk bushings wear bad. I have also heard the aev 2.5 wears the stock arm bushings at full flex. Not trying to bash either company, just wanted to know if anyone has has issues with either one. If stock bushings/mk bushings are so great why upgrade to tf monster joints/rk johnny joints?
Sorry dirtman but no wayoflife for me. Thanks for heads up though, may check them out. I was hoping to get some opinions on stock bushings/mk bushings vs tf joints and Johnny joints. I am planning on doing a lcog build and just trying to get some feedback. I want to do my build right with the best info possible.
As for joints there are several that will do fine for you. I actually run 4 different joints on my clog long arm and 40's with tons.
