Prestaging for 37s
Old Mar 25, 2014 | 01:43 PM
JKEmmert77's Avatar
Veteran: Navy
Default Prestaging for 37s
I know there are hundreds of threads on this and I apologize for it ahead of time. So I'm getting ready for 37's. But I want to have all the parts and have everything here before I put on 37's. So far I have thought about running synergy gussets, us alloy ball joints, maybe sleeves. I really don't have the time and or money for a truss as much as I would like too. Open to suggestions and or any advice that would be available to look at my options.
Old Mar 25, 2014 | 01:58 PM
courtsm3's Avatar
Look up dana 30 on 37's. Huge thread.
I went with all synergy parts up front. Gussets, sleeves, ball joints, tie rod, high steer kit, stabilizer kit with fox ss and track bar. Went with synergy coils too. Drives better then it did new. Should hold up to my 37's for now.
Old Mar 25, 2014 | 02:14 PM
09GRNJK's Avatar
I've had sleeves on my Dana 30 w/ 37's for about a year now. But have had the 37's on there for over two years. No breaks , no issues.
Old Mar 25, 2014 | 02:42 PM
JKEmmert77's Avatar
Veteran: Navy
My bad I should let u know I have a rubicon so I got the 44 up front
Old Mar 25, 2014 | 02:46 PM
Brightwhite's Avatar
I would do the sleeves and gussets still. I had a shop do mine due to the welding involved. I did Teraflex sleeves and gussets, I think the parts cost me around $200-300, and the install was about the same...I was out the door for something like $550 with parts, labor, and tax. Pretty cheap insurance if you ask me.
Old Mar 25, 2014 | 02:51 PM
JKEmmert77's Avatar
Veteran: Navy
I'm really debating the sleeves. Haven't really heard to much about them.
Old Mar 25, 2014 | 02:53 PM
JKphotoshoot's Avatar
If your not gonna change gears dont bother with 37's.
Old Mar 25, 2014 | 02:54 PM
JKEmmert77's Avatar
Veteran: Navy
Eventually I want too
Old Mar 25, 2014 | 02:59 PM
D_engel's Avatar
Pentastar with 4.10's and a 4:1 transfer case...He'll be fine
Look up the nitro sleeves. You can hammer them in yourself and its really not a bad install if you prep the tubes properly. Gussets are a must though, and you might as well swap the BJ's while you're at it.
Old Mar 25, 2014 | 03:01 PM
JKEmmert77's Avatar
Veteran: Navy
Originally Posted by D_engel
Pentastar with 4.10's and a 4:1 transfer case...He'll be fine Look up the nitro sleeves. You can hammer them in yourself and its really not a bad install if you prep the tubes properly. Gussets are a must though, and you might as well swap the BJ's while you're at it.
Eventually I will regear but the sleeves. Do you hammer them in or weld them in?
