Preventing Mirror Dent?
Old May 1, 2008 | 07:17 PM
Geeper4x4's Avatar
Default Preventing Mirror Dent?
Anyone know of a protective plate or other device to protect the cowling area from the dreaded mirror dent? I know I could just relocate the mirrors but is that the only solution out there? I could put some kind of heavy metal plate over the area but I would like it to look good also.
Old May 1, 2008 | 07:20 PM
Vexel's Avatar
I haven't heard of anything for the area.. but, honestly.. relocating is probably your best bet. IMO.
Old May 1, 2008 | 07:23 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
dont you have the straps at the bottom of the doors? or is that only jeeps with power windows/locks?
Old May 1, 2008 | 07:24 PM
SASQUATCH's Avatar
Make sure the door doesn't fling open and hit it. One thing I thought of is if you open the door all the way slowly, mark where the door meets, drill a hole the same size as the two rubber hood round windshield bumpstops, get a couple of those and put in there. Might look kinda goofy though, but would work.
Old May 1, 2008 | 07:27 PM
tkob1060's Avatar
Ek makes some limiting straps if you dont already have them
http://www.4wd.com/productdetails.aspx?partID=4619
Geeper4x4's Avatar
Yes, I have the straps. If you don't remove the doors it works great. If you take your doors off every chance you get you will forget just for a second and the door will swing forward ever so slowly. Then you will see a beautiful dent that just stays right in your view every time you walk by your Jeep.
Old May 1, 2008 | 07:28 PM
Geeper4x4's Avatar
I had thought of that idea as well. I think it would look bad enough to keep me from doing it though.
Good ideas .... keep em coming.
Old May 1, 2008 | 07:29 PM
pulman01's Avatar
Thats how I got my ding.
Old May 1, 2008 | 07:43 PM
Ctimrun's Avatar
Park facing uphill if possible (like up your driveway) and then if your doors swing at all they will swing closed......Only thing I can think of.
Old May 1, 2008 | 07:44 PM
MONGO!'s Avatar
I think of that cowl everytime I put my doors on or take them off. Once I unhook that strap, my hand does not let go of the door.
Get some lightweight diamond plate and make a cover for it. Might look okay, sort of like the corner guards
