Pro-comp accupro and 35-inch tires
Old Mar 17, 2009 | 12:33 PM
Default Pro-comp accupro and 35-inch tires
all,
I have a 2007 Unlimited X, automatic, with 4.10 gears. I also have a Pro-comp accupro programmer that will adjust shift points to account for larger tires. I have already re-programmed to account for the stock rubicon tires which replaced the stock 29-inch tires. If I were to go with a TF BB and 35-inch tires, will I really notice better acceleration just due to re-programming?
I do not want do my gears yet cause I'm still deciding on upgradinx axles.
Old Mar 17, 2009 | 04:22 PM
someone must be using a programmer and can tell me how changing the shift points may assist with bigger tires and how this will differ from changing differential gears.
Old Mar 17, 2009 | 04:27 PM
Stuka's Avatar
Well, it will basically firm up the shifts, and hold you in gear longer. So it doesnt bog down when it shifts to the next gear.
