pro comp wheel problem
Old Sep 5, 2010 | 09:50 AM
350ssindigo's Avatar
Default pro comp wheel problem
hi , I installed some pro comp 98 rock crawler last week ( with 40's ) and I just found out that the rim is not seating right, there is about 1/4 '' between the rim and the hubs, anyone with the same problem !!!
Old Sep 5, 2010 | 09:55 AM
mkjeep's Avatar
Were the washer /keepers taken off your hub? Something to check, doubt if they'd hold it that far away though.I'd pull a wheel and check for it.
Old Sep 5, 2010 | 11:32 AM
the back side of the rim is not flush , where the bolt patern is, its about 1/4 '' deeper than the rim, so when I bolt the rim it sits on the rim not the bolt pattern, kind of hard to explain but easy to see
Old Sep 5, 2010 | 12:11 PM
mkjeep's Avatar
post a pic
Old Sep 5, 2010 | 02:34 PM
I'll have to take the wheel of again, it looks like it would work with a 1/4 '' spacer
Old Sep 5, 2010 | 02:53 PM
mkjeep's Avatar
If you would, post a pic of the backside of the rim sitting against the hub, and also a close-up of the rim as you would be looking at it as if to change the tire.
