pro comp wheels !!
Old Jan 25, 2009 | 06:23 AM
350ssindigo's Avatar
Default pro comp wheels !!
hi, anyone of you have these wheels I'm going to buy them but would like to see them on a jk
Pro Comp 6001 18X9.5 backspace 4.5 offset -19mm
I'm gonna run them on 35 s , any pics please or opinion !
Old Jan 25, 2009 | 07:22 AM
JPop's Avatar
Too tall, too wide. 17x8s would be a better choice.
Old Jan 25, 2009 | 07:33 AM
I already have 18X8.5 and there not wide enough
Old Jan 25, 2009 | 07:42 AM
JPop's Avatar
Wide enough for what? The tire?
I'll back up for a second. What is the intended use of this new tire/wheel combination? If it's for off road purposes and on the trail both a lower diameter and narrower width is more desirable and less expensive. If it's for bling factor, I'm not the right guy to answer your question.
Old Jan 25, 2009 | 08:32 AM
my current 18X 8.5 rub on the sway bar on full turn and I like the look of wider rim and tire
Old Jan 25, 2009 | 08:44 AM
Dr.McNinja's Avatar
That's a backspacing problem, not a width problem. What tires are you running now?
Old Jan 25, 2009 | 08:47 AM
ScottK's Avatar
X2, if you're tires are rubbing you need less backspacing or wheel spacers.
Old Jan 25, 2009 | 09:08 AM
I actually have 2 problems, my 18 s have 5.5 back spacing and my tire are 325/60r18 (33x13.5r18 ) Id like the tire look better on a 10'' rim but 9.5 is the only one available, here spacer are 300 $ , if I trader My stock 18s + bit more money , I get another set of wheels ! without spacers !!
Old Jan 25, 2009 | 09:33 AM
ScottK's Avatar
I think you need to be running more like 3.75 to 4" backspacing with a 13.5" wide tire.
Old Jan 25, 2009 | 09:40 AM
JPop's Avatar
It's your call on what you want to do, but I'm not sure why you asked for opinions if you don't want to listen to them.
The wheel width doesn't have any effect on the tread width. Wider wheels make for less tire height and greater section width. Tires at the wheel width you are considering will be outside the fender flares, check your local laws regarding such. At the wheel width you are considering there is potential for rubbing on a stock front bumper. Beside that everything should be just ducky.
