Problem with Budget Boost!
Old Mar 30, 2009 | 04:51 PM
jdhanson's Avatar
Default Problem with Budget Boost!
I just got done installing the Teraflex budget boost and my whole front axel is off center by almost a half inch. Am I missing something? Or is there a way to adjust this? Will an alingment fix this? Any info would be great.
Thanks
Old Mar 30, 2009 | 04:56 PM
BBirish's Avatar
i think your trac bar is being pulled did you switch the sway bar links, does your steering wheel need to be recentered? you dont need to be worried though many peoples axels are off after lifting including myself i dont even notice it.
Old Mar 30, 2009 | 04:57 PM
Robar's Avatar
The axle shift is due to the lift. The way to correct this is to get an adjustable front track bar. You can use the adjustable track bar to recenter your axle.
Old Mar 30, 2009 | 05:07 PM
WilliamAWebb's Avatar
it is going to be off by a little bit. If it is a big deal to you, get an adjustable tracbar. That will help fix it. It is not that big of a deal though, mine has been like that for 6 months and no problems thus far.
Old Mar 30, 2009 | 05:11 PM
Suffolk JK's Avatar
Even if you don't notice it, your suspension cycle will. Your swaybar links, coils, and shocks will be ever so slightly tilted, when flexed or not. Properly do the lift by installing an adjustable trackbar and recenter your axle.
Old Mar 31, 2009 | 07:25 AM
BBirish's Avatar
Good to know
Old Mar 31, 2009 | 07:31 AM
robin's Avatar
all of the above
